Helix Variable Pitch- How to control it?
Hi All,
Currently i'm working on coil spring and facing some difficulties on the transition between pitch. As you may know, for coil spring we have active coil and dead coil, with two different pitch. In Helix feature in GSD they have this variable pitch function, however it was not easy to control. Example the transition between 10 mm pitch to 5 mm pitch, it will gradually change, like 10mm, 9mm, 8mm,......till 5mm.
Can i have the transition directly from 10mm to 5mm pitch??
