Hi All,
There's probably a reason that this question hasn't been answered before on these forums (unless I just didn't search hard enough), but I would like to know which method (or methods) forms the basis of the clustering components in Pipeline Pilot, seeing as there're many out there. Seems unfortunate I can't find out where this method came from, because I find it a very useful tool in my work.
I didn't manage to find anything after trawling through a few help files that seemed relevant.
A scientific paper/review reference would be most helpful (especially an original one)!
Thanks in advance,
Ed.
Ed,
The only information I could find are the comments on the RecenterClusters and RecenterCount parameters on page 70 of the same User Guide, copied below.
Malcolm
RecenterClusters:
Specifies whether to recenter clusters – i.e., to select a new cluster center for each cluster instead of keeping the original center. For each cluster, the new center is the one with the smallest mean distance to the rest of the cluster members (xxx option), or the one with the shortest maximum distance to other members (yyy option). Once new centers have been chosen, all other samples are re-assigned to the centers, as the selection of new centers may change the center to which any given sample is closest.RecenterCount:
If clusters are to be recentered, the number of times to recenter and recalculate the cluster members.
Ed,
There is a fairly extensive discussion of the clustering method in Chapter 10 of the Data Modeling Collection User Guide which you can find via the Pipeline Pilot Help Center or at http://doc.accelrys.com/library/PipelinePilot/doc/modeling.pdf This also contains some key references.
I have copied the key paragraph below.
Malcolm
The method for selecting the cluster centers is a
maximum dissimilarity method. It begins by randomly choosing a data record as the first cluster center. The record maximally distant from the first point is selected as the next cluster center. The record maximally distant from both current points is selected after that. The process repeats itself until there is a sufficient number of cluster centers. The non-selected objects are then assigned to the nearest cluster center to determine the cluster membership.Hi Malcolm,
Thanks, that's exactly what I need!
Though, is there any documentation I can find which explains re-centreing of clusters?
Ed.
