I have developed a protocol I want to call via web service. The WSDL file is perfectly generated and via the WSDL viewer I am able to test the web service. When I am calling the web service from an external program which is using the WSDL I have got an error on execute. The web service returns unable to load the protocol xxxx.
The login call is working properly.
I have found that if the protocol name contains a space or an underscore, in the wsdl the endpoint contains some encoded characters ( %20, %F5) and the pipeline server can not decode it and find back the protocol name. My program is working well if I remove all suspect characters from the protocol path and name.
Maybe somebody will know how to avoid that problem via some configuration.
thanks
I have found the problem. It is inside the library calling the webservice not the inside the pipeline pilot application.
My library is encoding the endpoint url which is already encoded. Also my problem is solved
