Visualize with Insight not working (Biovia Insight 2025)
How do I get the "Visualize with Insight" to work in Biovia Insight 2025?
The steps listed in the following document  are not working for me.
Welcome to BIOVIA Insight 2025 > For Administrators > BIOVIA Insight Installation Guide > New Installation > Configuring MongoDB
Error message:
"Import Failed:
Importing data into Insight failed because of an unexpected application error.
An error has occurred and has been logged.
If you see this error repeatedly, please contact your Insight administrator."
Answers 2
DB
DB 2025-01-02
Dear Michael,
as of version 2024 SP2, BIOVIA Insight requires a new version of MongoDB, namely 7 and higher. With it came a change in the installation and configuration procedure, and unfortunately, parts of the old instructions have remained in the documentation. We apologize for this inconvenience. The basic workflow is now:
  1. Download MongoDB 7 from the MongoDB project site and install it according to the vendor's instructions. We strongly recommend that you enable user authentication!
  2. Install BIOVIA Insight in your Pipeline Pilot server (you probably already did this part).
  3. After installing MongoDB and Insight, you have to configure the Pipeline Pilot server to use MongoDB. This is described in the chapter 'Configuring MongoDB' of the Insight Installation Guide PDF. If you have activated user authentication in MongoDB, as is highly recommended, you now create a so-called Tagged Resource in Pipeline Pilot that points to your MongoDB installation (server, port, username, password, authentication method). In earlier versions of Insight, you would have created a MongoDB-type Pipeline Pilot datasource at this stage, and if you still have that datasource from a previous installation you must remove it now.
  4. If you want to use a desktop editor such as BIOVIA Draw or Chemdraw to edit chemical structures, you also need to install and configure the BIOVIA Desktop Connector Messaging Service and distribute the BIOVIA Desktop Connector on the client machines.
Perhaps this information will already help you. If you require further assistance, please open a support ticket. My colleagues and I will be happy to help.
Best regards
Daniel Bongartz
BIOVIA Customer Success
MK
MK 2025-01-02
Hi Daniel, Thank you for your help. I am able to get the data visualization working now after installing and setting up MongoDB7.
