BioMart is a simple and robust data integration system for large scale data querying.
On this example I use the bioconductor package "biomaRt" to look for SNPs.
There are two examples with in the protocol.
The first one looks for SNPS on a particular gene
The second takes a list of values (same component as above) to retrieve a list of SNPs for a chromosomal region.
You need to have biomaRt package installed on your system. This post "Install Bioconductor Package" helps you with the installation.
Your result will look like:
This example need server access to the Biomart repository. If you are behind a firewall that blocks your call, please let me know, there are more ways to reach Biomart.
Hope this helps.
Pedro
