Unable to read any file on the server - error: pipeline pilot exception rethrown
Pipeline pilot is unable to read any of the files in the directory on the server - FYI - already proved that the server works fine. The error pasted below was applied to all the previous protocols as well. Any ideas are welcome. Thank you in advance.
Copied error:
The file '/projects/ccs/schurerlab/cheminfo/CommerciallyAvailableCompounds/eMolecules/20200401/version.smi.gz' could not be opened for reading.
FileDataReader::OpenSourceFromProperties: Pipeline Pilot exception rethrown
DataReader::onInitialize: Pipeline Pilot exception rethrown
FileDataReader::onInitialize: Pipeline Pilot exception rethrown
DelimitedReader::onInitialize: Pipeline Pilot exception rethrown
-> 'Delimited Text Reader' ('eMol'); Location: 27 - error during Initialization phase
CProtocolBaseImpl::GetNextStartNodeForNewData: Pipeline Pilot exception rethrown
CProtocolBaseImpl::SetUpComponentStack: Pipeline Pilot exception rethrown
CProtocolStd::onProcess: Pipeline Pilot exception rethrown
CProtocol::onProcess: Pipeline Pilot exception rethrown
CComponentRunner::CallOnProcess: exception caught, calling onFinalize before rethrow
Protocol SARS-Cov 3CL eMolecules prediction_0531, user jxh1011: Pipeline Pilot exception caught
Protocol SARS-Cov 3CL eMolecules prediction_0531, user jxh1011: Protocol failed: Pipeline Pilot error
Pipeline Pilot Server version 20.1.0.2208
Server OS: Linux
Answers 3
TK
TK 2021-07-13
I'm new to Pipeline Pilot, so please use it as a reference.
In the first place, can * .smi.gz files be read by'Delimited Text Reader'?
May I ask you why you chose that component to read the * .smi.gz file (such as the sample protocol you referred to)?
AC
AC 2021-07-14
@JH: ​​​​​​​this could happen if the Linux user trying to read the file does not have permission to read that file. Depending on how your PP server is configured, the file will be read either by the Linux user running the PP Apache server or, if impersonation is configured, the Linux user corresponding to the PP user running the protocol. My suggestion is to check the read permissions on that file for the appropriate user to see if that is the issue.
KB
KB 2021-07-14
A few additional notes:
Impersonation can be useful to manage access to external locations. If impersonation is off, all users will have the same access level as the owner of the Apache process itself. Turning on impersonation means that jobs have the access level of the user who launched them. The impersonation setting is on the Security->Authentication page of the Admin Portal.
You might consider moving the files to the "public" subdirectory of your server installation directory. Each user has their own folder within "public/users", and files there can be transferred between server and client.
Though I don't believe it would address this particular error, you may want to add a shorcut to this external location on the Setup->Folder Locations page of the Admin Portal.
