Tooltip
I am trying to convert a file of data file into plate objects with not necessarily unique identifiers. Each Plate_ID (specifies a different run) may have different species, genotypes in the same Plate_Map. I have the heat map and rich tooltip collapsed to a subprotocol (run to completion by category using Plate_ID, Species, and Genotype. However, I have to count @TI, then I have a very large tooltip with many data entries per tooltip Anyone have ideas on how to get around this so that my tooltips are correct?
Answers 4
LB
LB 2010-09-07
Mostly, you just need to be sure that the tooltip ids are unique in all cases.
I usually generate the IDs outside the subprotocol, and make them properties on
the record.
It is hard to be more specific without seeing the protocol.
Leo
LB
LB 2010-09-08
Yes, the attachments don't show in the email version...
Anyway, attached is a reworked version of your protocol that makes a single tooltip for each heatmap square.
The problem you were having is that you were concatenating all the tooltips with your tile components.  The tooltip subprotocol needs to be RTC if you have such aggregating components.  Also, I am creating the tooltip id (TTID) on the record, then converting it to a global inside the RTC subprotocols.  As they have different 'group by' properties each record needs to set the 'global' ttid value at the appropriate time.  I'm not sure this protocol is perfect, but it should point you in the right direction.
Leo
comment imagecomment image
JD
JD 2010-09-08
That's why I included it. If I count them outside the protocol, all of the heat map cells have the same tooltip, a gargantuan block of images and data.
JD
JD 2010-09-09
That works brilliantly. Thank you.
