Hello All
I am having some performance issues when running PP9.1. I am unable to run common commands like " ls " on certain directories
or the "df -h" command.
I am running Centos 6.5 (final).
Thanks in Advance for any help.
Which folder is this failing for?
Do you see any potentially relevant errors on the log files:
Best wishes,
Lynn
Thanks for the speedy response!
I am unable to run the “ls” command on the “/” directory.
I am unable to run the “df –h “ command.
This is only when the running PP…other than that the commands work…
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: line 3, Statement doesn't appear to do anything.
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: CEvaluateExpression::onInitialize: Pipeline Pilot exception rethrown
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: -> 'Custom Filter (PilotScript)' ('Library LIKE '%10k pilot%' OR'); Location: 17 - error during Initialization phase
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: CProtocolBaseImpl::PassDataDownstream: Pipeline Pilot exception rethrown
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: CProtocolStd::onProcess: Pipeline Pilot exception rethrown
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: CProtocol::onProcess: Pipeline Pilot exception rethrown
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: CComponentRunner::CallOnProcess: exception caught, calling onFinalize before rethrow
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: Protocol missy_excel_analysis, user user: Pipeline Pilot exception caught
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: Protocol missy_excel_analysis, user user: Protocol failed: Pipeline Pilot error
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: Pipeline Pilot Server version 9.1.0
[Sun Jan 22 13:41:53 2017] rndusljpp2.na.jnj.com.32440: Pilot Error: Server OS: Linux rndusljpp2.na.jnj.com 2.6.32-431.1.2.0.1.el6.x86_64 #1 SMP Fri Dec 13 13:06:13 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
[Sun Jan 22 12:32:19 2017] rndusljpp2.na.jnj.com.13913: WARN: Protocol execution timed out
[Sun Jan 22 13:25:02 2017] rndusljpp2.na.jnj.com.31398: WARN: Inactive pid (16158) found for lck file ppc04A0B-C4FB-B746-82A0-CDF01F371696
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.26829: WARN: CJobInfo::Init: stats file for ppc903C5-BD36-574D-93B2-E12197625377 does not exist ()
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.26829: Pilot Error: Unable to connect to stats file JOBID: ppc903C5-BD36-574D-93B2-E12197625377 USERNAME: mhack
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.26829: Pilot Error: wsRunner::GetJobStatus: Pipeline Pilot exception rethrown
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.26829: Pilot Error: wsRunner::sci__GetJobStatus: exception rethrown to SOAP
cd
error-rndusljpp2.na.jnj.com_log:
[Thu Jan 19 20:19:00 2017] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Thu Jan 19 20:19:00 2017] [warn] RSA server certificate CommonName (CN) `Accelrys Enterprise Platform' does NOT match server name!?
[Thu Jan 19 20:19:00 2017] [warn] pid file /opt/Accelrys/PP9.1_DS4.0/apps/scitegic/core/packages_linux64/apache/httpd-2.2.22/logs/httpd-rndusljpp2.na.jnj.com.pid overwritten -- Unclean shutdown of previous Apache run?
[Thu Jan 19 20:19:00 2017] [notice] Apache/2.2.22 (Unix) authnz_ses_module/9.1.0.13 mod_ssl/2.2.22 OpenSSL/0.9.8u mod_perl/2.0.4 Perl/v5.8.9 configured -- resuming normal operations
[Sun Jan 22 13:26:10 2017] [error] [client 172.21.6.145] File does not exist: /opt/Accelrys/PP9.1_DS4.0/apps/scitegic/core/web/Developer
les
scitegicerror_runprotocol.log
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.27328: Pilot Error: Unable to connect to stats file JOBID: ppc903C5-BD36-574D-93B2-E12197625377 USERNAME: user
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.27328: Pilot Error: wsRunner::GetJobStatus: Pipeline Pilot exception rethrown
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.27328: Pilot Error: SOAP Faultcode: SOAP-ENV:Server. Error code: 2
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.27328: Pilot Error: SOAP Faultstring: wsRunner::sci__GetJobStatus
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.27328: Pilot Error: soap_call_sci__GetJobStatus() failed
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.27328: Pilot Error: CRunnerSoap::GetJobStatus: Pipeline Pilot exception rethrown
[Sun Jan 22 16:09:01 2017] rndusljpp2.na.jnj.com.27328: Pilot Error: RunThatProtocol: Pipeline Pilot exception rethrown
logs/messages/scitegicerror_scisvr.log
First I should remind you that CentOS is not an officially supported operating system. Also version 891 of the software is in legacy support mode and when released supported RHEL 5, 6 and Suse 11.
I do not see anything obviously related in the log files. Can you clarify what you mean when you say it only fails when Pipeline Pilot is running -- are you running a protocol to retrieve the directory listing with a "Run Command (On Server)" component set to output the results of the ls command, or do you mean something else? What types of commands do work? If you are using a protocol, can you attach it here? If you are not using a protocol then how are you invoking these commands?
Best wishes,
Lynn
I am the Linux Admin for this team. I am slowly learning all of the software used by the team.
I am getting the answers to your questions about protocols.
I am referring to Linux commands only, specifically the "ls" command and the "df -h" command.
whenever the scisvr process is running, my linux system becomes unstable.
This could be related to the fact Centos is not officially supported OS. What is the latest version of PP?
Thanks Again for your help!
Is this a VM or a physical server? How much RAM does the server have?
If you log in to the software admin portal web page, what do you see on the main landing on the Spotlight section that gives a resource overview? If you click on the Spotlight resource image it takes you to a detailed resource usage page that you can also find under Status > Server Status. What is seen here? Is the resource level shown as "Critical?"
My guess is that your system is underresourced for the load, but I think it might be best to look in more detail with one of our support people -- you might want to call or email the support hotline to get more personalized assistance with your server issues.
Best wishes,
Lynn
I am getting the credentials now for the admin portal.
thanks.
