Name: Secure SMTP Mail Writer
Author: Ian Kerman
Version: 1.0
Created: 9/2012
Requirements: Pipeline Pilot 8.5 or later; Reporting Collection
O/S: Any
Known Limitations: None. However, this has only been tested against Google's Gmail service. If you test it with another service and find it fails, please let me know.
The following package contains a component that allows you to send e-mail through an SSL-secured connection, something not possible with the standard SMTP Mail Writer. Some services, such as Google's Gmail, require an SSL connection to send mail through their servers. With this component, you will be able to utilize these services if you have an account with them. The component is Java based and requires an extra Java library, so it has to be installed as a package. To do this, you may need to contact your server administrator.
To install:
1) Unzip the file and copy the resulting folder to
2) Run "
You will now have a new component called "Secure SMTP Mail Writer" and two example protocols.
It's not that you are supposed to "run" ppvars.sh but rather "source" ppvars.sh from the command line.
http://stackoverflow.com/questions/9326695/what-does-it-mean-to-source-a-file-in-unix-linux-context
Basically, it means that any environment variables set within the script stay put after the script finishes. You can do this via either of these commands:
"source ./ppvars.sh"
or
". ./ppvars.sh" (dot '.' is an alias for "source")
The error that you are seeing results from the environment variable LD_LIBRARY_PATH (where the system should find any dynamic .so libraries) not being set
Cheers!
Thanks for this Ian,
I'm trying to run the pkgutil from root using
./home/accelrys/PipelinePilot85CU1/linux_bin/pkgutil -i /home/accelrys/PipelinePilot85CU1/apps/accelryssupport/securesmtpwriter
However I'm getting the error message
"./home/accelrys/PipelinePilot85CU1/linux_bin/pkgutil: error while loading shared libraries: libpilot.so: cannot open shared object file: No such file or directory"
but libpilot.so is in the linux_bin folder along with pkgutil.
I found a post that suggested that running ./ppvars.sh before hand might help, but it hasn't. Any suggestions?
Thanks
Joe
Hi Joe,
I've updated the Secure SMTP Mail Writer component to now accept attachments. Again, I've only tested it with Google, but it seems to work well. You will need to reinstall the package, which you can do by using "pkgutil -r" instead of "pkgutil -i" after removing the old files and unpacking the new ones.
Regarding your observation with Office365, I think this may be related to a bug in the JavaMail library: https://jira.atlassian.com/i#browse/STASH-3482. I've upgraded the version of JavaMail that the component uses, so hopefully that will fix the issue. Please give it a try and let me know if it works. Thank you!
Ian
Hi Ian,
I've got this working well with our secure mail server - Thanks for your help. I also tried it on Microsoft Office365 (
http://community.office365.com/en-us/wikis/exchange/how-to-setup-an-smtp-relay-in-office-365.aspx) but couldn't seem to get it to work, not that its a problem for me.
However the secure SMTP writer doesn't allow for attachments like the unsecure SMTP writer does. Any chance of updating it to allow attachments? Alternatively if it does allow attachments in AEP9.1 thats great, as we'll be upgrading next week.
FYI - the error with Office365 was
javax.mail.AuthenticationFailedException: No authentication mechansims supported by both server and client
java.lang.RuntimeException: javax.mail.AuthenticationFailedException: No authentication mechansims supported by both server and client
at accelrys.Support.SSLSMTPMailWriter.SSLSMTPMailWriterComponent.onProcess(SSLSMTPMailWriterComponent.java:161)
at com.scitegic.pilot.Pilot.callOnProcess(Pilot.java:305)
Caused by: javax.mail.AuthenticationFailedException: No authentication mechansims supported by both server and client
at com.sun.mail.smtp.SMTPTransport.authenticate(SMTPTransport.java:760)
at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:673)
Cheers
Joe
Thanks for the quick response Ian,
The new version worked with office365 secure SMTP at first. It also worked with my own Secure SMTP server at first (as the last version did). However when I tried attachements it failed (error message below regarding java/nio/Paths). After this failure it can no longer authenticate with the Secure server or office 365. The error message is the:-
I did the install with the -r rather than -i as you suggested. I simply overwrote existing files with the zip then ran -r. After the AuthenticationFailedException I tried running the install with the -r again, but it doesn't recover the situation and I still get the javax.mail.AuthenticationFailedException: constantly.
So it looks like the attachments somehow kills all authentication with the Secure SMTP writer!
Attachment error below
Thanks
Joe
java/nio/file/Paths
java.lang.NoClassDefFoundError: java/nio/file/Paths
at accelrys.Support.SSLSMTPMailWriter.SSLSMTPMailWriterComponent.onProcess(SSLSMTPMailWriterComponent.java:185)
CComponentJavaPlugin::onProcess: Pipeline Pilot exception rethrown
-> Secure SMTP Mail Writer (Secure SMTP Mail Writer) - error during Data Record Processing phase
CProtocolStd::onProcess: Pipeline Pilot exception rethrown
CProtocol::onProcess: Pipeline Pilot exception rethrown
CComponentRunner::CallOnProcess: exception caught, calling onFinalize before rethrow
Protocol Email via SMTP, user jbradley: Pipeline Pilot exception caught
Protocol Email via SMTP, user jbradley: Protocol failed: Pipeline Pilot error
Pipeline Pilot Server version 8.5.0.200
Server OS: Linux server1.scitegrityonline.com 2.6.18-348.16.1.el5 #1 SMP Sat Jul 27 01:05:23 EDT 2013 x86_64 x86_64 x86_64 GNU/Linux
java/nio/file/Paths
Dear Joe,
I built the class against the Java SDK in AEP 9, which is JDK1.7, but Pipeline Pilot 8.5 uses JDK1.6. In 1.7, Java introduced the "Path" class, which I used, but this isn't available in older versions. I've rewritten a version for 8.5 which uses a different method. Please install this in the same way (pkgutil -r) and hopefully this one will work for you. I've also attached the AEP 9 version explicitly marked. Have a great weekend!
Ian
Hi Ian,
The 8.5 version would not instal with -r, so I re installed via -i
The -r error was
-+ Package accelryssupport/securesmtpwriter
Merging configuration files
Registering Components
FAILED TO REGISTER FILE: /home/accelrys/PipelinePilot85CU1/apps/accelryssupport/securesmtpwriter/xml/Components/Data Access and Manipulation/File Writers/SecureSMTPMailWriter.xml
Duplicate component name "Secure SMTP Mail Writer" already exists at path: /home/accelrys/PipelinePilot85CU1/apps/accelryssupport/securesmtpwriter/xml/Components/Data Access and Manipulation/File Writers/SecureSMTPMailWriter.xml
Registering Protocols
FAILED TO REGISTER FILE: /home/accelrys/PipelinePilot85CU1/apps/accelryssupport/securesmtpwriter/xml/Protocols/Examples/Generic/Secure SMTP Mail Writer/SendEmailFromGmailUsingTheSecureSMTPMailWriter.xml
Duplicate component name "Send email from Gmail using the Secure SMTP Mail Writer" already exists at path: /home/accelrys/PipelinePilot85CU1/apps/accelryssupport/securesmtpwriter/xml/Protocols/Examples/Generic/Secure SMTP Mail Writer/SendEmailFromGmailUsingTheSecureSMTPMailWriter.xml
Unregistering Components and Protocols
Unmerging configuration files
Package uninstallation successful.
There were errors registering components for accelryssupport/securesmtpwriter.
Summary:
There were errors registering the following components:
File: /home/accelrys/PipelinePilot85CU1/apps/accelryssupport/securesmtpwriter/xml/Components/Data Access and Manipulation/File Writers/SecureSMTPMailWriter.xml
ERROR:Duplicate component name "Secure SMTP Mail Writer" already exists at path: /home/accelrys/PipelinePilot85CU1/apps/accelryssupport/securesmtpwriter/xml/Components/Data Access and Manipulation/File Writers/SecureSMTPMailWriter.xml
File: /home/accelrys/PipelinePilot85CU1/apps/accelryssupport/securesmtpwriter/xml/Protocols/Examples/Generic/Secure SMTP Mail Writer/SendEmailFromGmailUsingTheSecureSMTPMailWriter.xml
ERROR:Duplicate component name "Send email from Gmail using the Secure SMTP Mail Writer" already exists at path: /home/accelrys/PipelinePilot85CU1/apps/accelryssupport/securesmtpwriter/xml/Protocols/Examples/Generic/Secure SMTP Mail Writer/SendEmailFromGmailUsingTheSecureSMTPMailWriter.xml
accelryssupport/securesmtpwriter was not installed:
The -i install successfully uninstalled and reinstalled, however I still get the error regarding authentication methods
As we are upgrading to AEP 9.1 this week I'll try again with the 9.1 install, although that will probably be next week.
Cheers
Joe
Hi Ian,
We’ve now upgraded to AEP 9.1 and the secure SMTP writer is working to a point. I can send e-mails (with the address being text, a data stream property or global variable).
However I can only send 1 defined attachment, which I have to pre-populate in the protocol before I run it, I cannot set it with a global variable or data stream property as with the non secure SMTP writer. This really limits the functionality.
For example
The non-secure mail writer logic for adding an attachment is to add the following string to the attachments box e.g
CSCS_Files/AutoAlertDocs/$(FILENAME), CSCS_Files/AutoAlertDocs/$(FILENAME2)
Where $(FILENAME) is from the property filename that’s been generated within the protocol and a file exists on the server
But this does not work in the Secure SMTP writer. I’ve also tried @FILENAME and FILENAME, but each time I get a file not found error, as it seems to interpret the variable as the filename
java.io.FileNotFoundException: @filename (No such file or directory)
Can the writer be fixed to allow parameterisation as with the non secure SMTP writer, or am I doing something stupid?
Thanks
Joe
Hi Ian,
I worked out how to send multiple attachments and parameterise as with the non-secure SMTP writer (after seeing Daves Hidden Tips and Tricks Webinar) making use of new AEP98.1 functionality.
For anyone interested...
To use attachments right click on 'attachments' in the parameters tag, then select 'initialise using' and select global property, data property or parent property. To attach mutliple properties select Pilotscript and enter the variables containing the paths as
@filepath.','.@filepath2
Thanks for you help and developing this secure SMTP writer with attachment
Joe
Hi Joe,
I know there was an issue with Office 365 earlier and I fixed this in "v2" of the Writer. Is this a different issue?
Unfortunately I'm not able to look into this issue right now, but the good news is that the source code is included with the package. Once you download and unzip the package, the source code is located in \accelryssupport\securesmtpwriter\lang\java\src\accelrys\Support\SSLSMTPMailWriter\. There is one Java file in there, which you can open in your favorite IDE or text editor.
I apologize for not being able to be more active on this issue right now.
Ian
Hi Ian,
I'm trying to use the Secure SMTP writer to send e-mail via Office365. When I used the connection information:-
SMTP host - smtp.office365.com
SMTP port - 587
I get the connection error:-
com.sun.mail.smtp.SMTPSendFailedException: 530 5.7.1 Client was not authenticated
Even with valid credentials - I've tried a couple of accounts and its the same.
I've done some googling and found a couple of possible reasons:-
https://connect.microsoft.com/VisualStudio/feedback/details/725279/smtp-tls-authentication-usedefaultcredentials-bug-using-office365-server-as-smart-host
http://community.office365.com/en-us/f/148/t/159381.aspx
The second one suggests it because TLS is not being used, but I assume the secure SMTP writer is using this, so I wonder if its the first issue.
As I can't see the code of the writer could see if either of these are likely? I can arrange an office365 test e-mail for you if it helps
Thanks
Joe
Thanks Ian,
I'll take a look at it sometime. For the moment I went down the path of least resistance and stuck with using a non Office365 mail server. Joe
