Why i am geting this erro, and is it due to license issue ? I cant use calculate PhysChem or even Canonical smile number of atoms.
error log:
Data type "SciTegic.data.Molecule" is not found in the current data record.
CCalculateAtomCounts::onProcess: Pipeline Pilot exception rethrown
-> Element Count (Element Count) - error during Data Record Processing phase
CProtocolStd::onProcess: Pipeline Pilot exception rethrown
CProtocol::onProcess: Pipeline Pilot exception rethrown
CComponentRunner::CallOnProcess: exception caught, calling onFinalize before rethrow
Protocol xx user xx: Pipeline Pilot exception caught
Protocol xx user xx: Protocol failed: Pipeline Pilot error
Pipeline Pilot Server version 8.5.0.200
Server OS: Windows 6.1 Server Service Pack 1
It is not a licensing error. There are records without molecules going into this component. To filter these out, use a Custom Filter with the following PilotScript:
Isupports('IMolecule')You will probably want to connect a Viewer to the Fail Port of this component for diagnosis.
If all the records fail, then you probably need one of the components in the Converters folder to create the molecule. This is common when reading from CSV or Excel formats aren't specific to chemical data.
Best Regards,
Keith
Sorry i forgot molecule component. my bad, Thanks for the input though.
