Run java on client
At some point of a protocol I am running a Java program on the server through the "Run Program on server" component and the following command lines:
cd \\\$(UserDir)/Lead-finding/tmp
/usr/bin/java testJava.PPM_2_EC50_Java inputFile.csv outputFile
For some reasons (and I'd like to know them ^^) it's pretty slow so I wanted to try with the "Run Program on client" to see if it could be faster and then I wrote:
"C:\\Program Files (x86)\\Java\\jre6\\bin\\javaw.exe" testJava.PPM_2_EC50_Java inputFile.csv outputFile
This doesn't work (maybe because I want to use file from the server or because the command line is wrong).
If you can help me make that works, it would be great
thanks
florent
