Retrieve SD files by Molecule Name
I have a list of molecule common names (i.e. Vitamin B12, ethanol). I would like to download an SD file for all the compounds from some public site (i.e. pubchem or anywhere else that works). Does someone have a protocol that would be able to do this?
Thanks in advance,
John
Answers 3
JN
JN 2012-01-24
Ian
The example protocols all appear to require a discovery gate license, even if I select to get info only from pubchem. Is this correct?
John
IK
IK 2012-01-24
Hi John,
A DiscoveryGate license is only needed if you are going to search the DiscoveryGate web service, so if you only enable PubChem searches, you should be ok. The protocol I attached should have only been setup for PubChem, so you can use that as a test.
Ian
IK
IK 2012-01-24
Hi John,
In Pipeline Pilot 8.5, we released some new components that search online databases such as PubChem and return the molecular structure. These components can be found under Components/Chemistry/Database Content and example protocols can be found under Protocols/Examples/Chemistry/Database Content. I have also attached a simple example protocol demonstrating this functionality.
Ian
comment imagecomment image
