Remove PATH from filename
I load some file into a component of a protocol, and I assign the filename+path to a global variable, @compound.
So for instance I get @compound like : C:\\temp\\whatever\\butane.sdf
How can I later create another global variable (i.e., @cmp), which is the same as @compound but without the path, i mean, in this case @cmp would be butane.sdf ?
I thing I should try something like
globalproperty('cmp') := FUNCTION(@'compound');
where FUNCTION removes the path, but in this case I did not find anything relevant on the help.
Or I also wonder about another solution to this problem (maybe I could read two variables at the same time in the component, one with the whole path and another one just with the filename? )
Thanks
