Does anyone know how to read a cache inside a parallel subprotocol? In the attached example, the protocol reads a file with records into a cache, then executes a subprotocol a number of times. The cache is read inside the subprotocol.
If the execution is on the same server, this works fine. However, If I change the execution to run in parallel, the protocol fails saying it cannot find the cache. What is the way to get around this problem? I want to avoid recreating the cache everytime if I can.
Thanks,
Liz
