I am attempting to use the R Cluster Diana component to do some hierarchical clustering on a series of compound subsets. To do this I am running this component in a subprotocol which I am running to completion. When I try to do this i get the following error. The protocol seems to work ok when the subprotocol isn't running to completion. I have attached s version of the protocol that reads in a SMILES file
> source("C:/Program Files (x86)/Scitegic850/apps/scitegic/rstats/lang/R/SciTegic/RFunctions.R")
> # If data form a distance matrix, no NA values are allowed.
> # Otherwise, only rows with all NA values are disallowed.
> diss <- (tolower("False") == "true")
> if (diss) {
+ rdata <- readData("H:/PipelinePilot/web/jobs8/me/{ppcAAC58-EBE7-4D5C-93CB-0DDFF2C07D0F}/temp/CE0F.tmp", removeZeroVar=TRUE, omitNA=TRUE)
+ } else {
+ rdata <- readData("H:/PipelinePilot/web/jobs8/me/{ppcAAC58-EBE7-4D5C-93CB-0DDFF2C07D0F}/temp/CE0F.tmp", removeZeroVar=TRUE)
+ # Omit any records containing NA for all properties
+ keep <- !as.vector(apply(is.na(rdata), 1, all))
+ rdata <- rdata[keep, , drop=FALSE]
Error in .subset2(x, i, exact = exact) : subscript out of bounds
Calls: readData -> [[ -> [[.data.frame ->
Execution halted
Could anyone suggest a possible solution to this?
Kind regards,
Sam
