Hi All,
I haven't seen any example code regarding the proper way to construct a Reader using the SDK and wondered if I am doing things the wrong way. In this example, I am determining in the OnInitialize method whether any records exist at all and returning the appropriate state. Then when OnProcess is called, I return the first record which was found in OnInitialize and try and look for another one. If there are no additional records, I return DoneProcessingData. If I don't do it this way, I end up gettting additional null records.
The concern I have is that I am potentially doing a lot of work in the OnIinitialize to get that first record (could be say a minute), does this cause any issues? It also makes things a little more complicated. It would be much easier if I could signal to the PP host on each call whether the current request yields a value. If I simply return a DoneProcessingData when there is no new value, I get a null row.
Thanks!
---Jonathan
public class SimpleSourceExample : IComponent
private IEnumerator
private int nextValue;
public State OnInitialize(IContext context)
//just gimme 10 steps and you won't see me no more!
source = Enumerable.Range(0, 10).GetEnumerator();
//first read could actually be very slow
if (source.MoveNext())
nextValue = source.Current;
return State.ReadyForNewData;
return State.DoneProcessingData;
public State OnProcess(IContext context, IDataRecord data)
data.GetProperties().Define("A Value", nextValue);
if (!source.MoveNext())
public void OnFinalize(IContext context)
If you told PLP, "I need to make a new data record" then changed your mind, you need to route the data record to nowhere.
In PERL:
$data->routeTo( pilot::NoPort );
This will cause the recorded to be deleted.
MK
Thanks! That does the trick!
--Jonathan
