Hi here comes my problem:
There are two colums, name and number, in my two excels A and B and I want to merge them using "Merge Data". However there are some arrays in A which have the same property "name", like line one to three are all "Jack" as the name property with no number. And I want to merge the correspond number 5 of Jack from B to A, while pipeline automatically writes the correspond number only once. So after merging my excel, there is only one line left with jack and the number. Initially I wanted to append all the empty numbers to jack in every line in excel A with no deletion of lines. So how can I modify the parameters so that I can achieve my purpose?
Thanks!
This is the format what I wanted after merging
| Name | Number |
| Jack | 5 |
| Jack | 5 |
| Jack | 5 |
| Jack | 5 |
This is the actual format after merging
| Name | Number |
| Jack | 5 |
I'm having trouble following what you're after. Can you show the input that would result in the output you provided?
Like Lee, I'm not sure what your input is. The Merge Data component will do as you describe. I suspect that what you want is a Join Data component.
Exactly! Thanks!
Join Data Component helped me out. Thank you all the same!
