I implemented a protocol in which the input is small molecule (like caffeine) that suffers some small flexible modifications. At the end I would like to get a picture, in the HTMl report, where one can see the superposition of both molecules in 3D from some eye perspective. Is it possible in Pipeline Pilot?
Thanks in advance
WS
Thanks in advance
WS
The freely available DS ActiveX control can be used to visualize and rotate 3D molecules within an HTML report. You can download this from our website (it is separate from the Discovery Studio Visualizer, but following the link below and registering will provide access to both)
http://accelrys.com/products/d...-registration-25.php
The attached protocol is a simple example that shows how output molecules can be piped into a reporting component that creates a 'live' 3D window in your HTML report.
You will also want to take a look at the SciTegic Example Protocol:
SciTegic Examples -> Reporting -> Forms and Selectors -> DS Visualizer Display Styles
Please note that since this is ActiveX, it will only work with Windows Internet Explorer.
Tedman
I too, am also very much interested in automated i.e. PP workflow-based, not GUI-based, molecular superposition in both 2D and 3D. Although one might attempt this using alignments using a MCSS, often this is not completely satisfactory.
There can certainly be cases where groups or side-chains can be rotated or adjusted in both 2D and 3D to give improved superposition, where the overlays of the original structures may not be optimal.
If anyone is interested in developing a PP protocol which gives the maximal possible overlay of 2 or more structures in 2D and 3D, especially for molecules with floppy side-chains that would be much appreciated!
Regards,
Jim Metz
Abbott Laboratories
1) Shape based alignment (create a shape from a target conformation and use Ligand Pharmacophore Mapping to align candidate ligands to the shape)
2) Pharmacophore based alignment (Build a Common Features Pharmacophore, the alignments are part of the output)
3) Substructure based alignment (generate conformations then align to a target)
4) Tether based alignment (Define tethers and align)
5) Molecular Field alignment (align based on maximizing electrostatic and steric interactions)
1-3 of these are already available as protocols in one form or another. The last two are available in the client or, by using DiscoveryScript, on the server. Attached is a simple example protocol that flexibly overlays a set of structures to a target. For more information and references see the DS documentation.
Certainly an optimal way of doing this would have be very useful for 3D QSAR methods (e.g. CoMFA). Given that there was never a great (even good?) method for automating these alignments, I'd be surprised if there was a simple solution.
I've got protocols that will apply 4 & 5 by the way, in a slightly different context, so if anyone is interested let me know and I'll extract the relevant bits.
