I am currently building a multi-step PLP report that will be used through the web-port. I am would appreciate some suggestions on how I can pass data tables from one protocol to another :)
Hi @DL. I hope I am understanding correctly that what you want is to pass tabular data between steps of a workflow. If that's what you mean, there are many ways of doing that. If it is a small amount of tabular data, you can convert it to JSON and then pass it to the next step as an additional parameter using the Additional Data to Pass parameters on the Input Form component, or the Hidden Form Data component. If it is larger amounts of data, then you can write it to a file in one step and pass the file path to the next step, which allows the next step to read the data from the file and use it. You can also use a cache, although make sure to use a user or shared cache, and you would have to deal with cleaning it up manually when the workflow is complete (easily done by setting the appropriate Cache Reader component to delete after reading), unless you always use the same cache name and overwrite any existing previous version. I attached a small example that shows all these three options. I'm sure other Pipeline Pilot users can suggest other ways.
