Does the Pipeline Pilot Oracle ODBCs support the INSERT INTO and RETURNING commands, in this case returning results written to a variable in oracle
I’m inserting records into a table and need to return the primary key which is generated by the data base using auto increment. I’m using the following syntax
DECLARE primarykey NUMBER(38);
BEGIN
INSERT INTO CSCS_DEV.SYS_LEG2SUB
(CSCS_DEV.SYS_LEG2SUB.PAGE,
CSCS_DEV.SYS_LEG2SUB.SECTION,
CSCS_DEV.SYS_LEG2SUB.RETIRED,
CSCS_DEV.SYS_LEG2SUB.RETIREDCOMMENT,
CSCS_DEV.SYS_LEG2SUB.RECORD_COMMENT,
CSCS_DEV.SYS_LEG2SUB.IDLEGISLATION,
CSCS_DEV.SYS_LEG2SUB.IDSYS_SUBSTANCE,
CSCS_DEV.SYS_LEG2SUB.IDSYS_MARKUSH_REG,
CSCS_DEV.SYS_LEG2SUB.CREATEDBY,
CSCS_DEV.SYS_LEG2SUB.MODIFIEDBY,
CSCS_DEV.SYS_LEG2SUB.DATEMODIFIED)
VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, (SELECT TO_CHAR(SYSDATE,'yyyy/mon/dd') FROM dual)
RETURNING CSCS_DEV.SYS_LEG2SUB.IDLEG2SUB INTO primarykey;
--dbms_output.put_line (primarykey);
END;
This is working in oracle directly, but when I run it in the pipeline pilot Insert component I cannot get it to output the variable primarykey. This is my preferred way of doing the query it means I always get the correct key. Is there a way to do this?
I’ve also tried a slightly different approach. In this case I use an Insert followed by a Select statement to pull back the last sequence for the primary key (this is a slightly less robust way as it feasible 2 closely timed updates could run in between the Insert and select)
SELECT ID_SYS_LEG2SUB_SEQ.CURRVAL FROM DUAL;
This is valid in Oracle directly, but the INSERT Component of pipeline pilot doesn’t like the Select statement and see’s it as an invalid statement “error executing sql: [42000][Accelrys][ODBC Oracle Wire Protocol driver][Oracle]ORA-00911: invalid character”
I think the INSERT INTO and RETURNING commands probably works, but I can’t see anything in the support documentation on how to retrieve the variable
Thanks
Joe
