Passing an array-type parameter using runjob.pl
What's the syntax required to pass an array -tpe parameter when using hte runjob.pl functionality.
Syntax for a simple parameter is as below:
http:///perlbin/runjob.pl?_protocol=&=&__QuickRun=true
How should I modify this to pass an array for the ? Maybe or ?
Is it even possible - the alternative would be to pass a string containng multiple values and have the protocol resolve that into an array.
Thanks in advance,
Tristan
Answers 2
JM
JM 2015-10-26 Best Answer
If you pass in the parameter multiple times, the protocol sees an array of values:
http:///perlbin/runjob.pl?_protocol=&=&=&=&__QuickRun=true
You could also pass in a set of delimited values and expand the results explicitly in the protocol.
TM
TM 2015-10-26
Thanks you - that's the information I needed.
Best regards,
Tris
