Parallel processing on PP2017R2 on RHEL7
Dear all,
I recently installed the brand new R2 version of PP 2017 on a RHEL7 machine. To my surprise I had to notice that each protocol where parallel processing is specified failed to execute with a nice error like that :
"An invalid index value (1736067536) has been detected; legal values are between 0 and 1"
The same thing works fine on a Windows Server. Is this a bug and known issue? How can I "repair" that?
Thanks in advance.
Peter Schmidtke
Answers 3
AM
AM 2017-01-25
Dear Peter Schmidtke,
We will need more details about this issue. Will you be able to open a case with BIOVIA.Support@3ds.com and submit: one of your protocols and data? It is difficult to know what might be going wrong.
Additionally we will need log files, scitegicerror_scisvr.log and scitegicerror_apache.log
AM
AM 2017-01-25
Dear Peter,
I talked to R&D and the issue might be a serious bug.
Please reply to me directly providing the following information:
       Are you using Hub authentication or Kerberos based authentication?
       Is this happening on every run or sporadically.  If every run, are some batches completing or is this the first failure?
       Could you send us the /logs/messages/scitegicerror_scisvr.log and scitegicerror_apache.log
       Please send the exact Pipeline Pilot version number (from Help/About… in the Professional Client or he can report the version from the blue title bar from the admin portal)
Kind regards,
Alyona MORZHINA
Alyona.MORZHINA@3ds.com
PS
PS 2017-01-26
Hi Alyona,
indeed I use Kerberos based authentication and this particular question gave me an idea of what might have happened.
If I authenticate as a local user (not part of the AD) then parallel processing works fine.
However, if I authenticate with a non local user (peter.schmidtke@discngine.com), the PP client authenticates me as peter.schmidtke. This has several effects:
1 : I have to login again on the web front end when using an HTML table viewer for instance
2 : Parallel processing doesn't work.
I digged a bit deeper and found that by adding the default domain name to the sssd.conf file enables the users to authenticate using only the user name (peter.schmidtke). I restarted sssd and now everything (even parallel processing works like a charm).
So in the end it's due to a missing default domain name that this happened on my machine, as I followed these instructions : https://docs.microsoft.com/en-us/azure/active-directory-domain-services/active-directory-ds-admin-guide-join-rhel-linux-vm
You R&D team might know what behaviour should be expected, but from a user perspective, logins with and without domain names should be accepted, as they are also accepted by the machine itself.
Or at least, if there's an issue in authentication during parallel processing, then this particular error should be raised.
Thanks for the hint with Kerberos.
Peter
