Oracle setup during server installation (LD_LIBRARY_PATH, EXTPROC_DLLS)
Hi all,
I have some troubles installing the server. Oracle had to be installed before and listener.ora has to be modified. But I don't know which paths I have to set. Can someone write me the paths I have to take into account for a proper Pipeline Pilot server installation.
Best regards,
Lina
Answers 6
LM
LM 2016-01-18
Hello Lina,
Pipeline Pilot does not require Oracle.
The software includes ODBC and JDBC drivers that can be optionally used with the included SQL components to help you connect to an existing properly configured relation database such as Oracle or SQL Server.  The key is to get things working for the database so it can be accessed generally and then Pipeline Pilot should be able to simply take advantage of that setup.
The database can be anywhere on your network -- you do not need to have Oracle installed on your Pipeline Pilot Server.
Are you able to connect to your database with tools like TOAD or similar?
Best wishes,
Lynn Miller
BIOVIA Support
LH
LH 2016-01-18
Hello Lynn,
Thank you for your answer. I also thought that Pipeline Pilot doesn't need Oracle but the Server Installer asked for "Oracle Home", "Oracle Service Name", "DBA Username", " DBA Password" and "Oracle Port" and this field are obligatory. That is why I installed oracle-xe-11. Before I only used MySQL and the JDBC driver.  I am not able to access the Oracle database and also don't need it but for Pipeline Pilot as I thought. There is no tool like TOAD installed. What should be filled in the Oracle related fields if I don't want and need a Oracle database?
Best regards,
Lina
LM
LM 2016-01-18
The Pipeline Pilot server installer does not request this information.
Are you installing the BIOVIA Foundation Hub or an application like Biological Registration, Chemical Registration or Insight that does require an Oracle instance?
Best wishes,
Lynn
LH
LH 2016-01-18
Hello Lynn,
the title of the window is "BIOVIA Direct 9.5" and it is the result of the executed Install.bin which was extracted from Direct-9_5_0_LinuxInstaller.tar.gz. I thought it is just the server but we have access to chemical and biological components. Do you mean this with Biological/Chemical Registration?
Best regards,
Lina
LM
LM 2016-01-19
BIOVIA Direct is a separate product described at http://accelrys.com/products/collaborative-science/biovia-direct/
Once installed you can use Pipeline Pilot to work with the Direct chemistry cartridge but assistance with installing Direct is best requested under the community topic area "Direct, Draw, and JDraw" which you should have access to if you are associated with a site licensed for Direct.
Best wishes,
Lynn
LH
LH 2016-01-19
Hello Lynn,
Thank you very much! Somehow, I downloaded not the Server Installer but the BIOVIA Direct. Now the Server is downloaded and installed. Everything runs fine!
Best regards,
Lina
