new user needs help
Dear PPSE users,
I ran Pipeline Pilot Student edition. However, when tried to start some
protocols PPSE aborted giving me warnings such as:
eg.:
for "Build DrugLike Model" protocol:
Component "Learn Good Molecules" is configured to run by reference.
However, the master component cannot be found.
for "01 Learn MAOInhibitor Model" protocol:
"Component "Learn Good Molecules" is configured to run by reference.
However, the master component cannot be found."
for "02 Use MAO Model to Mine Vendor Catalogs" protocol:
"line 1, The expression was trying to access the value on the data stream
for the property 'MAOInhibitorLike' but it is undefined or it could not be
calculated. One solution for this problem is to test for this situation
using the expression 'MAOInhibitorLike IS DEFINED' before using the
value."
for : "03 Use MAO Model to Generate Enrichment Curves" protocol:
"Component "Enrichment Plot Viewer" is configured to run by reference.
for "04 Find Typical and Atypical MAO Actives" protocol:
value."
for "05 Use MAO Model to Generate ROC Plot" protocol:
"Component "ROC Plot Viewer" is configured to run by reference. However,
for "06 Using the Learned Molecular Feature Viewer"
"Component "Learned Molecular Feature Viewer" is configured to run by
reference. However, the master component cannot be found."
for "07 Removing Features From the MAO Model" protocol:
"Component "Learned Model Viewer" is configured to run by reference.
Thats all of errors for now.
Whats happened? May be that I did not installed every requested issue I
dunno (think that all is installed but who knows...).
and of course, I installed R 2.6.1 before installing PPSE.
Can you give me a hand if possible.
Best regards
Zoran Matovic
Answers 6
TD
TD 2008-01-28
quote:
Zoran
Hi Zoran -
These examples require the Data Modeling Collection. This collection is not excluded by default in the Student Edition.
Sorry for the confusion. We'll make it more obvious in a future version if there are dependencies like that.
Regards -
Ton van Daelen
Accelrys, Inc.
ZM
ZM 2008-01-28
Hi Ton,
Thanks for answer.
By the way, for the sentence
"This collection is not excluded by default in the Student Edition."
do you mean "... is not included by..." or ...?
regards
Zoran
TD
TD 2008-01-28
Hi Zoran -
What I meant to say was that Data Modeling is a collection that is availabe for purchase with the free Student Edition. You can find more details here:
http://www.accelrys.com/products/scitegic/pp-student/
Regards -
Ton
Accelrys, Inc.
HP
HP 2008-01-28
Hello Zoran,
You mention that you installed R 2.6.1. I thought it would also be useful to note that this version is not officially supported in Pipieline Pilot 6.1.5 or PPSE. For these, the R Statistics Collection supports R versions 1.9.1, 2.0.1, 2.3.1, and 2.5.1, and any of these can be used, unless you have also got the Gene Expression Collection, which specifically requires R version 2.5.1.
Using a different version, such as 2.6.1, will lead to version warnings when you call R Statistics components.
Regards,
Lynn Miller
Accelrys
HP
HP 2008-08-13
In addition to the questions posed by the Topic Starter, I have the following question.
Also using the PP student edition with R statistics and the chemistry toolkit I wanted to visualize the contribution of different atoms to the activity of a compound in a model. I tried using the 'Generate 3D Spheres Using Atom Probabilities' component. However, despite the fact that I can use my trained model to predict activities on an external test set, I receive the error:
"..Model.. did not contain a learned model"
Is this because of me not having the modeling toolkit?
In addition, I cannot seem to get the 'Learned model reader' component to work. It does not output any data (including when I try using it on the models created by the example protocols)
Does anybody know any possible causes?
JS
JS 2008-08-14
Your guess was correct, those components are only for the Modeling collection, not for any models generated by R.
