I want to create a pipeline that will execute some queries on a MySQL database but it's a community version, so the datadirect driver provided with pipeline pilote is not working.
So I installed the one from MySQL, opened the ports and set the correct rights.
Then i tried to configure the odbc.ini file (Pipeline Pilot server is running on a linux machine), I used a SQL Open Connection component and I get an error :
Error logging into data source with connection string 'DSN=MySQL DB;UID=user;PWD=*****;': [IM003] [DataDirect][ODBC lib] Specified driver could not be loaded
I got the same error by filling in the informations directly inside the Data Source of a SQL Select component.
odbcinst.ini:
[MySQL DB]
Driver=/usr/lib64/libmyodbc5.so
The driver is located in /usr/lib64/libmyodbc5.so
odbc.ini:
[MySQL DB]
Driver=MySQL DB
Description=MySQL driver
server=address-of-server
port=3306
user=
password=
Database=mydb
socket=/var/lib/mysql/mysql.sock
There is an old post in the forum, from which i wrote these configurations files, but it's still not working.
Any help is welcome,
Many Thanks.
Fred
