Name: Microsoft Outlook .msg File Reader
Author: Ian Kerman
Version: 0.2
Created: 12/2013
Requirements: Pipeline Pilot 9.0.2 or later; Integration collection
O/S: Windows and Linux
Limitations: None known
Purpose: This component will read in Outlook .msg files that have been saved to a directory accessible to your Accelrys Enterprise Platform (AEP) server. The Reader accepts input data records containing a property that has the full path to the file, such as what would come from the List Files component. You can then optionally extract the To, CC, BCC and From names and e-mail addresses, the subject, the body, the e-mail headers and any attachments.
A note on attachments: Each attachment will create four new properties which are differentiated by an index. For example, if there were two attachments in your message, you would have both "Attachment_1_FileName" and "Attachment_2_FileName". There is an additional property called "Attachment_Count" which indicates how many total attachments there are. If you wanted to output all of the file names to the Debug console window in Pipeline Pilot using PilotScript, you could do something like this:
FOR #i IN 1 .. Attachment_Count LOOP
DebugMessage(Property("Attachment_".#i."_FileName") );
END LOOP;
To install, extract the attached zip file into your
