Mantel Test
Has anyone implemented the Mantel statistical test in Pipeline Pilot?  This is a test of the
similarity (correlation) between two distance matrices of the same rank.  Apparently the R
stats package, ade4, can perform this test, but it is not clear to me how to load the two
matrices, and obtain useful output i.e., the P value given a specified number of permutations.
Does anyone have either PP code or an R custom script example that they can share.
Thank you.
Regards,
Jim Metz
James.Metz@AbbVie.com
Answers 3
JB
JB 2013-11-12
Hi Jim,
Attached is an example.
I found it quite slow, with this small dataset, so it may be quite long for bigger dataset.
The input is two data already as distance matrices, then a tag is put to value 1 or somehting else to make the distinction between the 2 matrices.
The output of the R component is the coefficient and the pvalue. I used the ade4 library.
(I took some codes from the MDS component already in PP to get how the distance matrices are used)
As usual, it may break and I may come back with something more robust, depending of time.
Cheers
Jérémy
comment imagecomment image
AV
AV 2013-11-12
Hi Jim and Jeremy,
Try out this protocol.
I have simply adapted what is in this link  http://www.ats.ucla.edu/stat/r/faq/mantel_test.htm and fine tuned it to PP
Hope it helps.
Anand
JM
JM 2013-11-13
Jeremy and Anand,
Thank you both for your contributions and quick response.
Jeremy, your example protocol was especially helpful, simple, and clear.  I was puzzled
as to how to "feed in" two separate distance matrices, but, again your example is
easy to follow and worked just fine after I installed the ade4 R contrib package.  Thanks again.
Regards,
Jim Metz
AbbVie
