IUPAC name from molecule
Hi everybody,
With Accelrys Draw I can generate a IUPAC name from a drawn molecule.
I'd like to do exactly the same thing in a PP protocol from a SMILES string or whatever which format but I can't find a way to get this IUPAC name in PP.
Is it possible?
Thanks
florent
Answers 5
MK
MK 2012-07-19
Florent,
You really want to centralize AND AUTOMATE the naming of compounds.  As such, you actually want Pipeline Pilot to do the naming, not the end-user with an un-patched piece of software because your IT department forgot to update that user's computer.
In order to do this, you need to have 3rd party software installed on your Pipeline Pilot server.
I'm only aware of a few companies that sell software with that functionality.... and usually, it is only available as part of a larger bundle.
However, the Accelrys Direct Oracle cartridge has that functionality.  I believe they use the Open Eye software for "Name to/from Mol".
If you have Direct, let me know.
Mike Kutz
MK
FH
FH 2012-07-19
I don't have Direct.
It's not a big deal, having the structure is enough. Some chemists just suggested it could be nice to have the name above the compounds structure.
Thanks
HP
HP 2012-07-20
In Pipeline Pilot 9.0 we plan to add a name-to-structure/structure-to-name component to the chemistry collection. This componnet will include prototype features that enable input and output in languages other than the default American English style, and it will include a prototype translate feature that will take an input string and atempt to translate it to another language.
AA
AA 2012-07-20
While there isn't currently a component or function in Pipeline Pilot to calculate the IUPAC name there is an option to look up the name for existing molecules using either Discovery Gate or the public NCI/CADD.  These searches are combined in the Find Molecule Names component.  If you only want the IUPAC name you can use the
Molecule to Name(NCI_CADD) component under Chemistry > Database Content > Utilities > Internals > Individual Converters and set the Name Type parameter.  Note that, as an "Internals" component this will not show up in the Search box you will have to navigate to it.
Obviously, this won't help for truly novel compounds.
Malcolm
FH
FH 2012-07-20
Yes sure it won't help for new compounds, but this is already nice to have
