Interactive paged table
I tried to do an interactive paged table just by replacing the table component inside the paged table component by an interactive table.
It works fine ... time you don't touch anything. If you do any action (like going to the next page) you lose the interactive table which is replaced by a simple table!
Does someone know how to fix that?
Thanks
florent
Answers 8
MK
MK 2012-04-04
I was just disecting that component.
When you press "prev/next", it actually calls a completely different protocol.  You'll have to "fix" that one also.
There is a "protocol function" component within the "paged table" component.  Change that to point to your version of:
Components\Reporting and Visualization\Basic Reporting\Utilities\Internals\Paged Table\Paged Table Work Protocol
I haven't tried it myself... yet.
MK
FH
FH 2012-04-04
Yep, I tried to do that but the problem is it only keeps the columns I added inline. The columns I created "on the fly" upstream doesn't appear anymore.
MK
MK 2012-04-04
Did you make sure all columns/properties exist prior to sending the data records into the "___ table" component?
FH
FH 2012-04-04
I create them before yes, and they appear on the first load, but disappear if I go to another page.
FH
FH 2012-04-04
What is weird is that if I use the standard paged table component I don't have the auto-generated columns at all (first load and after)
LM
LM 2012-04-04
I am curious to know more specifically what you want to achieve.  The interactive table supports:
  • Edit: Allows the table to be edited.
  • Sort: Allows columns in the table to be sorted.
  • Reorder Columns: Allows columns in the table to be reordered.
  • Resize Columns: Allows columns in the table to be resized.
  • Hide Columns: Allows columns to be added and removed from the table.
Which of these functions are you exposing to your users?  Is the intention to allow content editing for later submission to a work protocol that will act on the edits?  Is the hope to allow users to do resizing but still let them sort -- but sort on a large table that gets displayed in pages?  What do you want carried from page to page?  How many rows of data do you expect (min-max)?  How many rows do you want displayed to the user per page?
I find that backing up and looking at the specific effect or functionality that is desired can lead to better answers since depending on your goal the best way forward may not involve the component you are trying to fix.  At the very least it leads to more focussed enhancement requests entered on your behalf.
Best wishes,
Lynn Miller
Accelrys Support
FH
FH 2012-04-04
I allow them to reorder, resize and hide columns.
I wanted to page my interactive table because when I have more than 100 rows it becomes slow. By the way I could have from 1 to more than 1000 rows (100 per page)
IK
IK 2012-08-09
Please try these protocols and see if they work for you. Depending on exactly what you are trying to do, you may need to change the inside of the subprotocol and the Work Protocol. Remember that any changes to the table must be done in both in order for those changes to be seen on the "next" pages.
Ian Kerman
Pipeline Pilot Support
comment imagecomment imagecomment imagecomment image
