Importing Specific Table From HTML
Thanks to the community here, I have a better understanding of how to import the data I need from text (txt) files. I was able to accomplish the goal I set, highlighted in this thread  https://community.accelrys.com/message/17675
Now...I need to perform the same task but by using the html file as the raw data. If you run the protocol I have attached (along with the necessary files), you will see that I am unable to sort the data into the correct columns (much less create the correct columns). When I was working with the text file I was able to use spacing to my advantage....that is not the case here. I need to create columns for:
Pos. [°2Th.], Height [cts], Rel. Int. [%], h k l
I then need to sort the correct data into the correct parameters. If I am leaving anything out, please let me know so I can elaborate more.
Thank you,
jlalb
Answers 7
BB
BB 2013-06-03
Hi jlalb -
Do you the the Documents and Text Collection on your server (formerly the "Text Analytics Collection")?
If so, starting in version 8.5 CU1, there is a component "Extract Table Data from HTML". This component reads HTML pages and outputs table data as pipeline pilot data records. I ran your file (NIST1976a_2.htm) through this component and it generated 9,856 data records, one for each row in each table in the file. That may help you with your task.
A couple of tips on this: First, there are 8 data tables in your file. The component reads all 8. You can pick between them using the "TableIndex" property on each data record. I.e., The 2nd data table with the 4 columns (Pos and lobs data) is TableIndex = 2. Also, the table column names become the property names by default. These names can be unwieldy, so, you can either rename for example "Pos. [°2Th.]" to "Pos" using the "Rename Property" component, or you can set the "Use First Row As Property Names" parameter to "False" and then filter out the first data record of each table (that data record will contain the table headers as data).
Cheers,
Brian
JL
JL 2013-06-03
I do have the "Text Analytics" collection or so says the admin panel. But I was unable to find "Extract Table Data from HTML" component. Is that not in my collection???
I have 8.5.0.200
HP
HP 2013-06-03
It looks like you don't have Collection Update 1 installed, otherwise the component should be there. Best idea is to check with your Pipeline Pilot admin to check the server and package versions.
Cheers,
Andrew
LM
LM 2013-06-03
Version 8.5.0.200 would refer to the base version of Pipeline Pilot, which was the same for the original 8.5 release as well as the CU1 and CU2 collection updates.  To see which collection update is applied visit your server home page and look at the blue title bar with the software logo.  Here on my test server I see:
Pipeline Pilot Server Home Page
Resources for Pipeline Pilot Servers and Clients
If it does not list a collection up then none is applied and you will need to upgrade to get this new component.
Best wishes,
Lynn Miller
Accelrys Support
JL
JL 2013-06-03
I am taking over the Pipeline Pilot environment. It is still very new to me (4 weeks experience). I am currently downloading CU5 in hopes that it will fix my situation. If this doesn't work I will post back...sometime tomorrow at the speed I am downloading.
JL
JL 2013-06-04
Thank you Pedro, that worked out for me. I just learned that the "Text Analytics" collection I have is only usable for the EKB system which is why it shows it active in the admin panel. Hopefully I will get to try out the "Text Analytics" collection soon so I can justify the needs for this specific collections.
Thanks again,
jlalb
PG
PG 2015-05-08
Jlalb,
You could consider also using the elements on the post https://community.accelrys.com/message/4469#4469 for your extraction. Based on it, I have built a protocol that extract your table.
The text reader will read the file using the end of file as delimiter. Also by looking at your previous post, the file you liked to extract was the table number 3 so I have only considered that one.
HTH
Pedro
comment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment imagecomment image
