Name: HTML Table Reader
Author: Kevin Neal
Version: 0.5
Created: Apr 2008
Modified: July 2008
Purpose: Extracts data from a table on a web page. One record is added to the data stream for each row in a table, except the first row which is used to identify property names. All records will have a property 'HTML Table Index' to denote which table they came from.
Requirements: Pipeline Pilot 6.1 or later
Reporting Collection
O/S: any
Limitations: Does not handle a table that has a title. It views the title as the property name for the first column.
Keyword: generator read html table reader pilotscript regular expression regex unmerge
Contents: HTML Table Reader.xml
HTML Table Reader Example.xml
Installation:
1. Unzip the archive.
2. Open the HTML Table Viewer Example protocol with Pipeline Pilot.
3. Run the protocol.
Updated to Version 0.6.
Improvements:
-Ignores nested tables
-Ignores table "Title"
Note that expressions were replace with parsing to support first improvement above.
Feedback is encouraged! Please leave a comment/thought/question/suggestion/request/demand/etc.
So, version 0.5 will grab anything from the first "
With version 0.6, the nested table will be preserved as html in the property. Just pipe this into another html table reader.
The example table brings up another issue. What if the table only contains one row? Or the first row is data instead of property names? Well, 0.7 addresses these issues by allowing you to name the columns.
If you must use version 0.5, make sure to remove the checkpoint that I accidentally left in...
Enjoy! And as always, feedback and examples are welcomed.
I'll give it a whirl. As I mentioned off-line I did manage to get what I wanted out of v05, but v0.7 does sound a more elegant solution.
Noj
I'm using this for a web-scraping application, with some of the Text Analytics components. So no, not ChemInformatics, but Competitive Information!
Noj
