How to use ROC viewer using Learn R Forest Model?
I have build the model using Learn R forest model.
Now i want to check the performance of my model using ROC plot viewer? Can anybody help me out with it?
Answers 1
DH
DH 2009-11-30
The Learn R Forest Model component produces a ROC plot for the "out-of-bag" (OOB) data if you select FitPlot as one of the R output options. This gives similar information to a ROC plot from cross-validation.
But if you have a separate test set and want to use the ROC Plot Viewer after building the model, here is what to do:
1. Send the test data into the built model component, and send the model output to the ROC Plot Viewer.
2. For each class in your input data, the forest model outputs a property whose name has the form _. Specify one of these properties as the ScoreProperty in the ROC Plot Viewer. (For a binary model, it doesn't matter which one. For a multi-class model, you'll get a different ROC plot depending on the class you choose, so you'll probably want to create a separate plot for each class.)
3. For the TestForGood, enter something of the form:
class eq 'classname'
where "class" is the name of the property in your test set containing the name of the actual class.
To be concrete, suppose you are using the model built by the example protocol "06 Learn R Forest Model for MAO Data". Then you should use "R_MAO_RF_active" as the ScoreProperty and "activity eq 'active'" as the TestForGood.
