how to draw dose response curve
hi
i am currently stuck on draw dose response curve using popeline pilot 7.XX, i dont know whta are exact steps to create dose response curve so can anybody guide me on same how draw dose respose curve?
Answers 6
LH
LH 2010-11-15
Have a look at the example protocol called "02 Calculating IC50 Values". It shows you how to set up data for the IC50 Report component.
LH
LH 2010-11-16
Sounds like you have not specified the property containing the response data properly (i.e. the record cannot find the property, so the record is sent to the fail port). Also, make sure the response property has been converted to log scale.
PD
PD 2010-11-16
On PP 7.5.x the IC50 fitting protocol example is called "IC50 Curve Fit example" (joined) and is in Protocos/Scitegic Examples/Data Modeling/Analysis.
It starts from a flat text file, computes statistics, then proceeds with curve fitting and eventually display curves.
Pierre
comment imagecomment image
DH
DH 2010-11-16
Actually, it's the X property (concentration) rather than the Y property (response) that you normally take the log of in a DRC analysis.
HP
HP 2010-11-16
thank both of you for my entry level question, i am trying both examples can u recomend me any good learning material for curve fitting and drc
,btw my sample data always go to fail port when using Dose Response Fit component
thank you once again
LH
LH 2010-12-01
Ooops. Right.
