I am wondering if there is a way to extract the binding location of primers that are identified by the "Find Primers" node?
Answers1
HP
HP2008-11-05
SAC stores primer binding site predictions in the Feature Table, which is stored as a hierarchical structure. Components are available to extract the amplicon, and a nice example protocol can be found on the Protocols tab titled "Generating Primers and Amplicons".
I think your question is slightly different -- and that you are looking to get the start and end properties for each predicted primer to be stored as a top-level property on the original data record.
There are many ways to do this, and I encourage you to search the on-line help for "deep properties" to get pointed towards hints on using these in PilotScript. For features like these, where there can be more than one and you need to loop to get them all, I personally like to use the Perl (on server) component for the task.
Attached you will find an example where I have done this. In it I redundantly create a array-based top-leval properties for the start/ends and also create separate properties with names like start.1, start.2... just to show how both can be achieved -- typically you would choose one or the other for your purposes.
Regards,
Lynn Miller
Accelrys, Inc.
