Getting array value along with other corresponding values.
Good evening,
I am trying to get a minimum value that has been manipulated already by the Resize Function. Is there a way to get a minimum value and other corresponding values? (they are also all in column properties).
Example:
Column 1/Array A = (1,3,5)
Column 2/Array B = (2,4,6)
Column3/Array C = (7,8,9)
Desired output:
Column 1 = 1
Column 2 = 2
Column 3 = 7
Thanks a ton.
Answers 2
LB
LB 2024-05-14
Hi-  The 'Sort Array Property' component might help. This component sorts an array value and reorders any other properties' array values that are given in the Dependent Properties parameter. Set column2 & Column3 as Dependent properties and then take the first value of each.
MP
MP 2024-05-15
@GB If you don't need to keep the original data, then you can follow the 'Sort Array Property' component (Descending) with an 'Array Property Resize' component with a size of 1. That will just keep the first (highest) value.
