How to extract SD file with given input of parameters. For example: SD file contains 1000 structures with IDS, I want to extract 400 Structures SD file.
Answers2
HP
HP2009-05-29
If it's just the first 400, then you can just set the maximum parameter of the SD reader component. If you want a random mix then use a random percent filter?
Or is this a different question?
HP
HP2009-05-29
Hello Kiran,
As Neil noted you can either set a value for maximum on the read step, or can read the entire file and apply filters to get the desired set. You might apply a Random Percent Filter, but other options are available that can allow you to do selections based on property values and other criteria. In PP 7.5 you might browse through the Data Access and Manipulation > Filters and Chemistry > Data Access and Manipulation > Filters
sections of the Components Tab to see more options relevant for SD inputs.
I would like to note that I moved this topic into the General Discussion board from it's original post on the topic for complete examples. I hope you do not have any trouble finding it in it's new location.
and
Best wishes,
Lynn
