Error pop-up Window
Hi all,
    I would like to ask, if in the implementation interface click a parameter protocol button, and then PLP background for some data query, if the data is not right how to return to the implementation interface an error pop-up window which only retains the information I want to show?
Answers 2
AC
AC 2024-04-03
Hi @DH. It's not very clear to me what you mean by "implementation interface". How are you running the protocol? From a web browser using Web Port? From your own web interface?
LB
LB 2024-04-26
Some options @DH might be to end the protocol and return an error string as the result JSON; or (in the pro client) to use the Display Message for Each Data or Display Message component after the fail port of the component where the missing/incorrect data is causing the issue. Further, in the pro client you can use the Ask a Question component if the user would be able to give the missing data to allow the protocol to proceed.
