I have a protocol that reads data out of a file, checks various values against different database tables, and adds data when it is not found in the database. The protocol is set up to execute all of the SQL for a file as a single transaction, so if an error is found, all database changes can be rolled-back. On larger files, I will receive the error below on random SQL Select components after running for a while. None of the select statements retrieve more than a single column from a single row. Is Pipeline Pilot caching the results of every SQL query in memory for a single transaction? Is it possible to clear this cache after each record completes pipeline? We are using Pipeline Pilot 8.0. Thanks for the help.
No more memory is available: 5000000 objects of size 1 requested
vcByteArrayCache::MemFileInfo::WriteBlock: Pipeline Pilot exception rethrown
vcByteArrayCache::MemFileInfo::WriteDataBlock: Pipeline Pilot exception rethrown
vcByteArrayCache::WriteDataBlock: Pipeline Pilot exception rethrown
vcByteArrayCache::EndRecord: Pipeline Pilot exception rethrown
vcCache::SaveRecord: Pipeline Pilot exception rethrown
CRDBMSComponent::onProcess: Pipeline Pilot exception rethrown
-> Get gene ID if missing (SQL Select for Each Data) - error during Data Record Processing phase
CProtocolRtc::onProcess: Pipeline Pilot exception rethrown
CProtocol::onProcess: Pipeline Pilot exception rethrown
-> Subprotocol 1 (Subprotocol) - error during Data Record Processing phase
-> Parse Job files (Subprotocol) - error during Data Record Processing phase
-> RNA-SEQ (Subprotocol) - error during Data Record Processing phase
CProtocolStd::onProcess: Pipeline Pilot exception rethrown
Protocol NGO Parse Data, user oemler: Pipeline Pilot exception caught
Protocol NGO Parse Data, user oemler: Protocol failed: Pipeline Pilot error
Pipeline Pilot Server version 8.0.1.700
Server OS: Windows 6.0 Server Service Pack 2
