Good day,
I'm currently using the Java SDK for Pipeline Pilot to develop an Blast application that downloads locally the first result file, either a PDF file or a HTML file.
To perform this download, I use the command:
StJobResult prr .....;
Sring[] results = prr.getResultFiles();
PipelinePilotServer.getRemoteFileManager().downloadFile(results[0], localResultFile);
as it's shown on the Pipeline Pilot Help Center.
This protocol works fine with a PDF file.
The problem appears when I want to download a HTML file. In this case the "result.html" file is downloaded but not the related pictures.
These pictures are created but they stay on the server.
When I have a look on the server side, and more precisely on the "job id" folder of my protocol I have got:
- result/
- result.htm
- RunInfo/
- temp/
all the pictures related with the htm file are in the result folder, but they are not downloaded.
How can I download everything at once?
Do I create a loop to download all the pictures in the result folder or is there a quicker way?
Many Thanks
Pierre
- result/
- result.htm
- RunInfo/
- temp/
Many Thanks
Pierre
