is it possible to influence the spacing of data labels on the axis of report plots, like heatmaps?
Or even better could I define which labels to write there?
Thanks for you help,
Jens.
Jens.
Well, when looking at Heat Map (quick glance) ... the parameter X-Axis>Label ... is a string; you could probably pretty easily change this to an expression type and format what you want it to be labeled as.
As far as spacing goes for the font, the only way I've found to really manipulate that is to make the size of the chart bigger. You could probably easily create a relationship for how big you want the chart to be based on how many points you have on the x-axis, which would theoretically space out your labels.
Oooh... ya... you could always defined a new property, format it to to your liking, and use that as the property to establish the x axis... something like:
%'X Axis Label' := %ID . "-" . %Some_other_prop
I don't know if this helps at all, but it's an idea.
You are right and my post was misleading. I was thinking of the labels at tick marks, not the Axis Label itself.
So far I was told it is not possible to define the tick marks like in other plots.
I did come around that using a scatterplot, but it does not look as nice as a heatmap :-(.
Cheers, Jens.
That's something to work on. I did not think in this direction. Thanks I'll try it.
