Hi all,
I'm interested in using a data connector to tie together a visual selector and a bar chart. It looks like this isn't directly supported in v7.5, but is this possible via a workaround?
Also, I've been making use of tooltips to provide mouse-over information in visual selectors. Is it possible to adjust the delay before the tooltip data appears? On the toolips I've set up, the information pops up as soon as the mouse cursor hovers over the object, and I'd prefer that there be a short delay.
Thanks in advance for any guidance you can provide.
Best regards,
Scott
Best regards,
Scott
-Jules
However, if you really wanted to use a Visual Selector, 8.0 also contains a scriptable API for the data connector, so you can register your own JavaScript method that could listen for data connector events, and then simulate Visual Selector clicks. Check out the "Scriptable Data Connector" demo for an example of using this API.
Regards,
Warren
-Jules
