I use a column component to generate a table. and I want to add a check box into the head of a column.
Unfortunately it display these text in the head of the column literally and there is no allow_html_tag options for this component. Is there any easy way to do this?
Thank you.
You can use the Header component to create column headers that are more complex than just simple text. This can include a checkbox. The attached protocol gives an example of setting up such a header, though it doesn't actually do anything with the checkbox once selected.
Malcolm
Thank you.
Used this trick today, in conjunction with this post outlining the javascript for a Select All checkbox: https://community.accelrys.com/message/8378#8378
Thanks for posting this on the forum
Tris
