Calling a protocol in a secondary server
Hello all,
I would like to open a web form from one server, which passes data and calls a work protocol in a differnt server via the input form component. Can anyone help me with the correct format of the string that needs to be entered into the input form component?
Thank you
Answers 3
JK
JK 2016-02-10
I have found that the easiest way to do this is by putting the pipelines that you want to run remotely in a subprotocol, and then declaring it a parallel subprotocol. This allows you to specify which remote server you want to run on. The results will be returned to the protocol on the original server where you can prepare the web pages to present to the user.
RK
RK 2016-02-12
Thanks John. Trying it out, but having a bit of trouble when I try to communicate between a linux and windows server, or between linux servers. Seems ok when using two windows servers strangely
JK
JK 2016-02-12
Probably something in the authentication settings. We use it between Windows servers in the same domain, and have not had issues.
You may want to try a web services call using the SOAP Connector. (That is how we did it before we found the parallel protocol trick!) A bit of extra work, but you can enter proper authentication and parameters pretty easily.
