I could not find the Bioster in the support matrix, the protocol 'Generate Bioisosteres of Known Drugs' complains "Dataset based on the full Accelrys Bioster database. This data is not included with the Bioisosteres components in Pipeline Pilot. It is available for users who have a valid license to the Bioster database. In order to use the full Bioster data, the property "BiosterDatabaseLicense" should be defined as a global in the Server. This property should contain a valid license key for the Bioster database."
Thanks!
Hi Tobias,
BIOVIA no longer distributes the BIOSTER database.
The option to use the full BIOSTER data in the Pipeline Pilot components is no longer supported.
The only exception would be users that happen to have a perpetual license for the BIOSTER database, and even in that case we would need to check to make sure the license is valid.
We will remove the option to access the full data in an upcoming release.
Moises Hassan
