Alt+tab navigation
Hi
When the PilotScript (or any type of PP parameter window) window is open, I cannot reach it through Alt+Tab navigation. Is it normal? And if so, is it something that will be worked out?
Answers 7
HP
HP 2009-11-14
IMO, it's common to have applications' modal dialogs not show up in the alt-tab list. A quick run through my Microsoft, Oracle, and Adobe apps seems to confirm that. When you have a modal dialog open, alt-tabbing to the parent app should cause that dialog to be the active window, too.
Why is it important to have the dialog be alt-tabbable?
HP
HP 2009-11-17
I still don't understand. Why can't you do that now?
I'm in a PilotScript dialog typing some stuff in the editor. I alt-tab to a browser. I click around in the browser. I then alt-tab back to Pipeline Pilot. The PilotScript window is still there, activated, and the code editor has the focus so I can immediately continue typing.
GM
GM 2009-11-17
When I have a PS window opened, Pipeline Pilot is not accessible any more by Alt+Tab. I wish I could printscreen the Alt+Tab "window" showing the different icons of reachable applications: PP is not one of them.
HP
HP 2009-11-17
Hmmm... that's weird. I have both Windows 7 and Windows Server 2003 workstations here and both allow me to alt-tab to and from PP just fine.
GM
GM 2009-11-17
Well I'm using Windows XP Pro SP2 and I had the problem since I've started using PP 16 months ago.
I haven't realised it was a bug; I'll drop the issue to PP support.
HP
HP 2009-11-17
FWIW, I just tried on a colleague's machine that's XP with SP3, and alt-tab works just as my Windows 7 and 2003 machines do.
This sounds like a perfect justification for your company to upgrade your workstation!
GM
GM 2009-11-17
When typing some PS or other programming in a PP dialogue, you often look for information in another application (a db browser, a javascript help page, etc).
And it's handier to browse through the different windows with the keyboard only.
