Hello, Biovia Pipeline Pilot uses ALOGP98 as the refinement of atom-based method published by Ghose and Crippen for calculation of ALogP. However, l would appreciate if someone would refer me a paper that Biovia Draw 2018 also uses the same approach.
BIOVIA Draw uses the PP Chemistry .NET SDK to calculate AlogP values. The results you see with Draw should be exactly the same as the results you get with the Pipeline Pilot AlogP component.
Thank you for your reply!
