Access a server behind a gateway
at work we have set up a server. But if we want to access it from outside, we should first ssh a gateway machine, and then we can access the server thorugh ssh, so there is no direct access from outside. Is it there any method for PP to access the server?
Answers 2
SB
SB 2009-06-13
Hi Werner,
There are a number of options, but since you already have access via ssh, I would first take a look at using SSH Tunneling (http://souptonuts.sourceforge.net/sshtips.htm) to accomplish what you need. In a nutshell, you would use the SSH client (e.g. Putty) to establish a tunnel connection via your Gateway to the Pipeline Pilot server, then connect Pipeline Pilot (or Webport) to your local machine as though it were the PP server.
I have never tried this particular method, so I hope it helps.
JS
JS 2010-07-06
I've used this method before, and it's pretty easy to set up. You'll need some sort of SSH client on the machine you're trying to connect from (such as Cygwin) and use these three commands:
ssh -L 9944:pipelinepilotserver:9944 sshgateway
ssh -L 9943:pipelinepilotserver:9943 sshgateway
ssh -L 4443:pipelinepilotserver:4443 sshgateway
Then from the Pipeline Pilot client enter the server name as "localhost".
