Hi All,
I was wondering how the young's modulus as well as Possoin ratio can be calculated from the Forcite module. I can read the results from the file, but I don't know how these values are calculated.
I know that the bulk and shear modulus can be calculated from the stiffness matrix through Reuss/Voight/Hill theory. But I don't know what theory is applied in order to calculate the Young's modulus and Possion ratio.
Thanks for your help in advance.
Shin
Hi Shin,
Have a look at the Mechanical properties topic in the Materials Studio help (Theory > Classical simulations theory > Calculating properties). In particular Eq. 123 and 124 shows how the Young's modulus and Poisson ratio are calculated from the Lamé coefficients that feature in the stiffness matrix.
Reinier
Hi Reinier,
Thank you for your answer. But I think your answer is correct if the material is assumed to be isotropic. Eq 123 and 124 cannot be used for anisotropic material. I got different Young's modulus in terms of x, y, z directions. But I don't understand how these values were obtained.
Another question is that in Forcite module use "constant strain approach" to calculate elastic constants. Is it the same method in the CASTEP module?
I think Forcite uses the method, "the second derivatieves of the energy with respect to strain." so it does not calculate the stresses exactly, right?
But it seems that the CASTEP caculate the stress, and then use the strain-stress relationship.
Thanks for your help.
Shin
Hi Shin,
You are right, the Young moduli are obtained from the compliance matrix, and not from the Lamé coefficients.
The relation is E(i) = 1/S(i,i), where S is the compliance matrix (the inverse of the stiffness matrix C). You can verify this using the reported compliance matrix, taking into account the difference in units (E in GPa, S in 1/TPa).
Likewise the Poisson ratio follows as ν(i,j) = −S(i,j)/S(i,i), which again you can verify using the reported data.
The stiffness matrix itself is obtained by imposing a strain pattern (e.g. [1 0 0 0 0 0]) and evaluating the associated difference in all stress components. In general there are 6 strain patterns to be imposed; less if the system has symmetry. You find the list of strain patterns on the Forcite Mechanical Properties dialog when the structure document is in focus.
So Forcite does not actually use the second derivates of the energy; it estimates those by numerically differentating stress with respect to strain. I believe the same approach is used in CASTEP, although I stand to be corrected on this.
Best,
Reinier
