what does the magnitude of RDF signify
Hi all
I have some questions about RDF. What does't the magnitude of RDF signify? I'm reproducing the results of a published paper. I used the same model, used the same computational methods. My RDF curves have the same shape with those in the paper, but the magnitude is several times larger than that in the paper. How is that happening? I did something wrong with the methods or the analysis process?
Thank you
JIngjing
Answers 1
RA
RA 2012-04-05
Hi Jingjing,
As commented in and , the value of g(r) tells you how dense the system is at a distance r from a particle, relative to the density in an ideal gas.
You should find that at large distance the function goes to 1, indicating loss of interaction with the particle at the origin.
Perhaps you could add a screenshot of the expected and observed curves?
Reinier
