What does the error mean for the electric field calculation by Dmol3
Hi everyone,
        Is there any one who knows why when I applied an external electric field on the Z direction of a molecule interaction with CN sheet. The job has been failed.
Cheers
water
Answers 5
FH
FH 2017-03-29 Best Answer
Dear Water,
to see what happens to your system, I simply animated your trajectories with the 'monitor bonding' option enabled. You see the CO2 dissociating and the surface being severely distorted - I don't think that counts as 'stable'.
I checked again on the keyword documentation (and source) for the electric field keyword, please note that this is in atomic units. The field you have selected is 0.05 a.u. * (27.211/0.529  V/A / a.u.) = 2.58 V/Angstrom. This is an extremely high field which can only be achieved very locally with field ion microscopes. As far as I know, most STMs will not be able to produce such a field, and it certainly would not count as normal operating condition anyway.
Presumably you want to see what happens when you apply a voltage to the surface, which would correspond to substantially smaller fields. I would start with a field that is ~10 or even ~100 times smaller and then slowly increase to check on the effect of the field.
Notwithstanding any of the above, we should probably adjust our documentation and put in smaller numbers into the keyword example to make sure that copying the example will not materially alter the chemistry of your system...
All the best,
Felix
CM
CM 2017-03-27
For me is not clear why the job failed. Perhaps /tmp is simply full.
Please post the *.xsd file from which the run was started and the directory of the failed run in your Materials Studio project. Please delete all *.tp* files from the *.zip file before you post it.
HZ
HZ 2017-03-27
Hi Carsten,
      Here is the calculation process. Hope you can find why it fails.
Cheers
water
comment imagecomment image
FH
FH 2017-03-29
Dear Water,
thanks for uploading all the files, they certainly help in interpreting the job.
Your calculation is slightly problematic in that both the molecule and the surface break up in the process. If this is all you wanted to know, you are pretty much done already and possibly you don't need to run this calculation to the end.
However, if you do want a good result, here is the problem:
DMol3 uses the electron density of previous geometry optimization steps to generate a starting guess for subsequent calculations. This is to accelerate the SCF cycle when there are only small changes in the structure. In your case, the structure breaks up during the calculation such that the initial guess for the density is quite useless toward the end of the calculation and this leads to very wrong forces. I actually tried to run your final geometry step from scratch and it converged without problem.
Your issue should be resolved if you add the following line to the .input file and then run from file:
reset_scf on
This will start a new SCF cycle without initial guesses for every single geometry step. In most cases this is slower (hence not available from the UI) but in your very special case it will likely be the only thing to make the calculation complete.
Best,
Felix
HZ
HZ 2017-03-29
Hi Felix,
         Thanks for your kind help.  I just wonder what do you mean "both surface and molecule are break up in the process"?
          I have done several calculations with different configurations for these systems without the external electrical field.   The binding between the molecule and surface is around 0.2 -0.3 eV, which means the molecule can be adsorbed onto the surface with my experiences.
       I just wonder to test the effect of the external electrical field on the interactions between the molecule and the surface.
 Do you got some good suggestions?
Cheers
Water
